Cam and Spring swap Question
Old 06-04-2010, 08:44 PM
jasonsti
jasonsti's Avatar
Cool Cam and Spring swap Question
Going to do it this weekend. I am assuming the spring change needs to be done with the cams installed to use the spring compressor. Is it better to do this before or after the cam change or does it matter? Also, can I get away with not charging the cylinder with air or is that a necessity? If its needed, what's the best way to do it?
jasonsti is offline
Old 06-04-2010, 10:35 PM
jwharton
jwharton's Avatar
First off, welcome from a fairly new member myself. There are lots of good "how too's" here just search for them and check out sticky's. You are thinking with pushrod mentality, not overhead cam mentality. Read the attached link and it will get you going.
https://mustangforums.com/forum/gt-s...ion-guide.html
jwharton is offline
Old 06-04-2010, 11:02 PM
hammeron
hammeron's Avatar
yes read through those guides and if there was more time
maybe JDwalton could have given you some pointers. he just
did springs and cams.
hammeron is offline
Old 06-04-2010, 11:13 PM
808muscle
808muscle's Avatar
I used hammerons write up but I only did cams.
808muscle is offline
97SN95GT
09-13-2015 09:45 PM
raleigh05GTO
09-04-2015 07:09 AM
cbird1177711
09-02-2015 08:51 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: Cam and Spring swap Question
