Fixed my throttle response issue.
Old 07-15-2010, 08:22 PM
evilspock
evilspock's Avatar
Default Fixed my throttle response issue.
So I cleaned the TB and it worked wonders. I took it off to clean it, real easy. At first i thought I was wasting my time because it did not appear to to be that dirty. But before it felt like I had to push the pedal a few inches to get response, now I can feather it! Thanks MF'ers!
evilspock is offline
Old 07-15-2010, 09:06 PM
BigDinTexas
BigDinTexas's Avatar
Good job... Glad to hear your success.
Don
BigDinTexas is offline
Old 07-15-2010, 11:22 PM
Nuke
Nuke's Avatar
You gotta love the simple things in life. Had you taken it to a shop you'd be out at least $100.
Nuke is offline
Old 07-16-2010, 08:15 AM
incorrigible
incorrigible's Avatar
Curious: Did you reuse the TB gasket? The Ford manual says to replace it.
incorrigible is offline
Old 07-16-2010, 08:26 AM
Lifter583
Lifter583's Avatar
I also shimmed the throttle arm its self to take the play out of the pedal movement...
Lifter583 is offline
Old 07-16-2010, 02:00 PM
drewsky
drewsky's Avatar
wow that sounds real sweet actually.. how many miles on your car when you cleaned it out? i live in az as well, kinda been dry and dusty till monsoons, ill bet my tb is dirty as hell
drewsky is offline
Old 07-16-2010, 06:08 PM
evilspock
evilspock's Avatar
Yes I did, it looked fine. Looks like a orange rubber o-ring thingy. I cleaned the mating surfaces well.
Old 07-16-2010, 06:11 PM
evilspock
evilspock's Avatar
37 K. I just bought it so I dont know the history on it. Did not look bad to me. Was a carbon like black soot build up, not dusty looking. Yea 116 today... holy crap! My car was at operating temp before I started it!!
Old 07-16-2010, 08:30 PM
jahudso2
jahudso2's Avatar
What did you clean it with? Did you use carb cleaner, or just paper towels and stuff?
jahudso2 is offline
Old 07-17-2010, 12:48 AM
evilspock
evilspock's Avatar
Carb / TB Cleaner (Autozone $1.50?) and a clean rag. Sprayed into the pivot points really good and wiped it clean..
Wondering if maybe the pivot points should be lubricated? Anyone?
Quick Reply: Fixed my throttle response issue.
