Running a Vortech/Paxton Non-IC'ed.
That high of a compression ratio creates a ton of heat to begin with. Throw a supercharger into the mix and your car will constantly be pulling timing whenever it's the least bit hot outside and the engine is warm, especially at city speeds. It's inefficient and hard on the motor. Having said that, you are correct that there are plenty of guys who have run non-IC F/I with little to no issues. It all depends on how willing you are to stay out of the boost when conditions are not favorable for it. Good luck either way, I was just throwing out my 2 cents.
aye.
yeah.. the boost is right where it's supposed to be
Kicked in like a freight train!
http://www.youtube.com/watch?v=RDuc_Uvfg0o
http://www.youtube.com/watch?v=w9sDo...eature=related
Heres how my car accelerates with the centri. I ended up adding an intercooler a month after I did the non-ic kit because you leave so much power on the table.
That was intercooled.
Here is non-intercooled on a 100 degree day, hot lapped 4 times:
http://www.youtube.com/watch?v=A6Xx2L4_LhQ
And here it is right after it was supercharged:
http://www.youtube.com/watch?v=l3IGd63ww9Y
