whipple question...
Old 08-02-2010, 04:43 PM
MustangRacing4.6ltr
Kenmore Fan
MustangRacing4.6ltr's Avatar
Default whipple question...
inquiring for father in law has 07 shelby gt, that he put ho whipple charger on 1 year ago and runs about 10 -12 psi up here in colorado..over the period hes had this charger ,he keeps having trouble with his belt slipping ...hes even brought it back in to the dealer for them to tell him the same thing....so he keeps replacing the belt and then it keeps slipping after a month or two ..another thing he noticed is on his last couple of wot runs ..hes only able to get 5 psi out of his charger ....what do you think is wrong ??? he is acutally gonna order the expensive idler pulley system that consists of the 10 rib ( i think) belt----hoping that that helps...do you think that will solve it? any info helps -thanks
MustangRacing4.6ltr is offline
Old 08-02-2010, 06:52 PM
solidsnakegt89
solidsnakegt89's Avatar
I have a whipple system on my 08GT. I have heard of some problems with peoples belts slipping, although i havent had a problem yet except idler pullys breaking on me. Not sure if the belt could be causing your to loose boost PSI. Its a little $$$ but you could check out the steeda belt drive system for whipple SC's. I beleive the boost pulley is 11-13 PSI and with a good dyno tune that thing should run like a champ. Also I would call whipple about this situation, i have delt with them a many of time and I think there service is quite helpfull.
solidsnakegt89 is offline
Old 08-02-2010, 10:20 PM
SpartaPerformance
SpartaPerformance's Avatar
How many miles are on the car?? Sounds like it may be a weak idler pulley. Does he have the right size belt? He didn't install underdrive pulleys before the Whipple did he??
SpartaPerformance is offline
Old 08-02-2010, 10:33 PM
onederful100
onederful100's Avatar
sounds like the loss of boost is from the belt slipping.
belt slippage and pulley squeal is not uncommon for TS SC.
i would suggest you start with a heavy duty tensioner like the Thumprrr. i have the thumprrr with the 90mm pulley and 8 rib kit.
http://www.thumpracing.com/index.htm#belt_tensioners
http://www.bggperformance.com/index....dex&cPath=7_13
no need for the steeda 10 rib kit at that low boost level, the 8 rib kit which replaces all the pulleys and replaces the serpentine belt with a 8 rib belt is sufficient and can be run at 20+ psi without problems, and is cheaper than the steeda one.
onederful100 is offline
Old 08-02-2010, 10:34 PM
onederful100
the tensioner alone may fix your problem.
Old 08-03-2010, 09:49 AM
Diabolical!
Diabolical!'s Avatar
A Thump_rrr tensioner solved my belt slip (and bent tensioner) issues.
Diabolical! is offline
Old 08-03-2010, 04:56 PM
yzf29
yzf29's Avatar
just another thought- I would check the free roll of the components the belt drives to make sure one is not binding- slip the belt off and spin the idlers, alternator, supercharger- may not answer your question - but easy enough to do>
1/2 drive socket on the tensioner and the belt slacks to allow for the check.
Steve
yzf29 is offline
Granatelli Sales
03-21-2016 06:16 PM
Bokeo
10-10-2015 08:28 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
GWFoos
01-08-2009 11:42 AM
Scooterman
05-12-2005 11:44 AM
Quick Reply: whipple question...
