power problem? electrical
ok im not to sure wats wrong with it but, my car deck keeps turning off randomly and coming back on randomly.. i have the shaker 1000 system.. my deck completely loses power and goes blank and while that happens my wiper blades dont even work. so there is no power going to the deck or wipers... dose any one know the problem? its random.. comes and goes.. and i check all the fuses there all fine
Are you aware of the TSB for the water leak issue so prevelant in the 05's, 06's and even a bit into the 07's? It's a known cause of all kinds of electrical gremlins.
I've seen this issue only with a weak battery, you mentioned you stored it did you put it on a trickle charge for a while at least every 2 weeks? Best way to see if it's a weak batt is to get a multimeter and see what the output is it should be around 12.45 while the engine is off and 14v when on.
