Stock rear gear?
I know on my '07 manual that 3.55's were standard.
My '07 GT/CS has a code of CG which is 3:31's. 3:55's were a option, but had to be ordered in '07.
Then again......after checking the window sticker it does list the "3:31 Limited Slip" under "Optional Equipment".
I also have an 08 manual GT that came with 3.31 gears. I swapped them for 4.10 gears, which were a nice improvement.
According to the order guides for each year, 3.55's were standard on '05 and '06 GTs with manual transmissions. 3.55's were optional for the '07 GT with manual transmission only. Although mine came with factory installed 3.55's, they were also listed as an installed option on my window sticker. The same is listed in the order guide for the '08 models. For '09 the options changed with the addition of the 3.73 gear ratio.
inyadreems
08-21-2015 09:10 AM
