5speed swap to 6 speed anyone?
does anyone know what we need to swap a t56- 5 speed from s197 mustang gt to a 6 speed transmission?
i found this "BA21 05-10 Mustang GT 6 speed Transmission Installation Package" at http://www.ddperformance.com/shop/pr...58cPath=108_95
is it worth it? or u guys have more better ones?
Ray,
It's been done by alot of people. You can save alot of money by shopping around for the transmission. You will need a transmission, shifter, 26 spline clutch, crossmember, and driveshaft if you are still on the stock one.
I documented my swap to help anyone thinking about doing it.
https://mustangforums.com/forum/4-6l...s-removal.html
https://mustangforums.com/forum/4-6l...-part-2-a.html
Ray,
Not so much performance wise, it all depends on how you set it up. The real benefit is the increased strength of the transmission and as you mentioned gas mileage. The main reason people do a swap is because our 3650 only has a 10 spline input shaft and often snap at higher power levels, plus the synchros are weaker. It really sucks that they don't offer upgraded internals for the 3650.
There are plenty of 3650 broken input shaft pics on different forums. All of them I've seen are a result of hooking up with a high horsepower motor.
You get a gear between 4th and 5th.
4th on both is a 1:1 ratio of engine RPMs to driveshaft RPMs
on the 5 speed, 5th is .68
on the 6 speed, 5th id .80 and 6th is .64
I SO want a 6 speed, but the dollars aren't there... yet.
mungodrums
09-29-2015 09:18 PM
musnicki
09-23-2015 07:11 AM
jaiidutch
09-14-2015 10:29 AM
