Question On Cleaning Throttle Body!
As for "ham fist" tight, I think it can be best described as tight as you can get it, leaning into the wrench with your weight, etc.... If you get it that tight, you probably torqued it more than needed...
Don
Its a thin clear baked on powder coat to fill any porosity in bore casting and blades,
it help in reducing scratching and dirt buildup.
That why you use TB cleaner so it doesn't destroy it like some chemicals melt
powder coats.
powder coats.
I cleaned mine about two months ago. I had to rub pretty hard to get all the carbon buildup off, but no harm done. I didn't use a torque wrench to tighten it up and its doing just fine, so I wouldn't worry. Just as an aside these tbs get pretty dirty pretty quick. I had to replace mine in March 09 (allegedly according to the dealership) and when I took it off there was a fair amount of buildup behind the butterflys. Also the cleaning helped for a while I think (or it could have been because I unhooked the battery) but it came back a month later and I had to replace the tps in the dark after work.
Just one thing to add for FI applications-- you may need to take of the passenger side sender to reach the lower bolt due to the cooler hoses. BE VERY CAREFUL WITH THE TORQUE SCREWS THEY BREAK IF YOU ARE NOT GENTLE. I BROKE BOTH BUT SAVED THE THREADS ON THE TB. IT WAS NOT FUN...
Resurrecting this thread...
For those of you cleaned your TB, did you do it while it was still on the car or did you remove it entirely? I need to clean my this weekend and see if I can't figure out the 'pulsing' idle I'm experiencing right now.
I removed mine completely, sprayed with cnc and wiped with a cloth on both sides. Used alternating pattern when reinstalling the screws. My pulsing idle and almost stalling upon startup went away immediately. Took maybe 30 minutes.
