08 GT: opinion on mods
Hi, I wanted some advice on my build plans for a 2008 GT 5 speed with 25,000 miles. I'm looking for the car to run high 11's or low 12's. I won't use this car as a daily driver, but then again I probably should. I'll drive this car mostly on the street with an occasional run down the track:
1. Kooks full header without cats, Corsa axle back.
2. mosier 31 spline axles, detroit locker & 4.10.
3. Ram clutch & spec aluminum flywheel.
4. Hurst shifter
5. Diablo programmer
6. Rousch cold air induction
7. MSD coils
8. FRPP GT500 Upgrade Fuel Pump??? if I add supercharger.
After I complete this list I want to install new cams.....not sure what cams to look at (Comp Thumper?). Also I'm not sure if there is a good aftermarket intake available or maybe a supercharger? Any thoughts or suggestions will be appreciated. Thanks in advance.
4. Hurst shifter
7. MSD coils
