Tuner question
Tuner question
So I ordered my SCT tuner with BAMA tunes for AM. I was wondering since I don't have the stock tune (I have the FRPP tune) and it says that the tuner holds the stock tune, will it hold the FRPP tune too?
I would imagine it would.
Call them to check.
When the SCT first asks you if you want to download the stock tune just
hit yes.
I can't remember if it asks you or if it auto downloads it the first time you
hook it up to the computer.
Call them to check.
hit yes.
Make sure that when you get the programmer, you read the "Strategy Code" by going to Vehicle Info > Vehicle Info. The strategy code is what you have to program using, you cannot use your stock sticker code, unless you return to stock with the ProCal tool.
If I read you correctly, it sounds like you ordered your tunes using the code off of the PCM's sticker. If so, you'll likely run into a problem trying to load the tunes so ABSOLUTELY do as Chris stated above in his post, first thing before trying load a new tune. I'd then call AM and give them the strategy code. They may need to e-mail you revised tunes. If you try to load the incorrect tune, you run the risk of ending up with a no-start condition until you get the tunes straightened out.
Of course, if you have the ProCal and can return to stock beforehand, then the point is moot.
Yeah, the more I read through it - I realized that had to be ordered off the sticker.
^ Do what he said above, give us a call when you get your device so we can read the strategy instead of the sticker.
I like going off of the factory sticker, anyway. So, preferably I would like to get that ProCal tune out of there and back to stock. However, if you cannot we can work off of it.
Luke9222
10-22-2015 11:55 PM
Daddys Girls GTs
09-14-2015 08:46 PM
ernesto-619
09-10-2015 01:32 AM
