Fog light fuse
http://iihs.net/fsm/?dir=1
Try the wiring diagrams. Also, I know I have a PDF of the OM for the '06 at home and might have one for an '05. PM me with your e-mail and I'll forward one later today after work.
Troubleshoot... http://iihs.net/fsm/?dir=40&viewfile=Fog Lamps.pdf
Begin by verifying the bulbs are good. Do you have a VOM? Check for voltage at the sockets and work your way back OR begin by verifying voltage at the fuse and work your way forward. You might even want to begin at the switch.
Odd that it will go with no mitigating factors to start with, but don´t assume just because you can´t see a break that it´s good. Use a Digital multi-meter (continuity/ohm/resistance check) to verify the fuse is ok.
