How to REMOVE Steeda crank pulley?!
Anyone know what "puller" or device I need to remove the Steeda UDP crank pulley? Doing an SC install and for some reason assumed I used the same puller as the OEM crank pulley... nope.
Any help would be greatly appreciated. I need to get this thing off! |
I used a steering wheel puller like this one: http://www.amazon.com/Advanced-Tool-.../dp/B000OUW77A
The bolt size is 10mm x 1.5 threads, 7-8cm long, you need 3 of them. You can rent one from an autoparts store, I had to buy the bolts. |
