Underdrive pulleys, CAI and tuner
Old 06-07-2011, 09:41 PM
columbia_stang
columbia_stang's Avatar
Default Underdrive pulleys, CAI and tuner
Hey guys got a couple of decisions to make and wonder if you all can help. I just received my Steeda CAI and getin ready to purchase a tuner. My toss up is between Bama or Steeda tunes. As for underdrive pulleys, has anyone had any issues with their car running warmer with them and are they worth it. I had underdrives on my old foxbody and it always seemed to run alot hotter in the summer with the a/c on. Thanks
columbia_stang is offline
Old 06-08-2011, 06:45 AM
Nuke
Nuke's Avatar
AM/Bama has the edge IMO.
UDP's shouldn't cause any issues with your AC and charging system unless you're pushing some heavy duty power thru your alternator when sitting at idle at which point you'll be loading the engine a bit more mechanically and canreduce your idle speed, compounding things. But IMO it shouldn't be a problem otherwise.
Nuke is offline
Old 06-08-2011, 03:24 PM
TheYeti
TheYeti's Avatar
lifetime tunes is hard to beat. I had bama tunes with my CAI and they were not only fast but had great customer service.
TheYeti is offline
Old 06-08-2011, 04:28 PM
Mishri
Mish-ogynist
Mishri's Avatar
I'd go with Bama.
Mishri is online now
Old 06-11-2011, 05:07 PM
columbia_stang
Ok thanks guys, guess I will go with bama tunes. Still undecided about UDP's because I fixin to install my stereo system pretty soon and since it will be pulling the car down the UPD's may not be the way to go right now.
Old 06-11-2011, 06:24 PM
rshamekh
rshamekh's Avatar
Bama is the way to go!
And you should probably hold back on the UDPs
if you are going to install an aftermarket stereo
system; no significant gain there anyway.
I would also recommend Optima Yellow-top battery
for that purpose.
rshamekh is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Jb145700
08-21-2022 06:37 AM
baddog671
07-26-2016 01:20 PM
spdeplayer2
10-24-2015 09:45 AM
junior04
09-28-2015 10:53 AM
Quick Reply: Underdrive pulleys, CAI and tuner
