rear o2 sensor w/ o/r h pipe question?
hey guys quick question my last car was an srt4 neon and when i put the cat delete on i bought a non-fouler drilled it out enough so the o2 sensor would screw in but not all the way through and installed between the pipe and o2 sensor so the computer to see a difference in the 2 sensors and it worked. my question is will it work on my 05 gt? or do i need a sct cuz i cant find mil eliminators for the 05. any feed back would be helpfull thank you.
Depends on what kind of inspections you have to get done, and whether OBDII emissions are checked as part of your inspection. Rear O2's turned off won't help you in those locales. The moving-out the rear sensors using non-foulers is a trick that seems to help.
