Another "whipple threw the belt" member
#41
This should give you an idea of how to attack the issue: http://www.mapro.skf.com/products/AL_intro2.htm
#42
Here is a link to a DIY 8 Rib kit
https://mustangforums.com/forum/4-6l...onversion.html
I would also suggest like others have to check your pulley alignment.
the UPR tensioner works very well, the Steeda looks like you need a 1/4" extension on your breaker bar.There is not much room for a 1/4" extension between your tensioner and your radiator.
http://www.uprproducts.com/mustang-b...ioner-arm.html
Get a 1/2" extendable ratchet from Harbor Freight and keep it in your trunk
http://www.harborfreight.com/hand-to...het-98831.html
#43
If he's already got a thump and is still shredding belts, then no aftermarket tensioner will fix the problem. Alignment of at least one of his pulleys is definitely off.
#44
Lol, designed a competitor? Tell me, what's the failure rate on the thump? I'm not gonna bash the two-stock-tensioners setup because I've never personally used it, but the thump works fine for everyone who uses it.
#45
I use a Thumper tensioner and it works very well, never a problem.They are pricey tho.There are other tensioners out there that will do the job for a little less money.
