Anybody flushing their trannys anymore?
I change mine every year since I race so much.
Working at a shop last year, I did a few filter changes.. the fluid that comes out is pretty nasty.
Be aware that simply dropping the pan on an auto only releases a minor amount of the total tranny fluid volume. The only way to do a complete exchange is with a power flush.
Correct, but if you drop the pan at reasonable intervals, say every 40k, it will keep everything working properly without disturbing any potential buildup in the tranny.
I've had my wife's Escape power flushed at 60K and the stang at 30K..flushed as in they push fluid through the system in the opposite direction until it comes out clean.
ZERO problems.
the longer you wait to do this the more likely you will have major deposits and sludge that will come loose when you have it performed. Just like regular oil, wait long enough and there will be sludge. A drain and refill really does nothing since about 50 to 60% of your fluid is in the torque converter, tranny lines, and tranny cooler.
ZERO problems.
ZERO problems.
ZERO problems.
Its cheap maintenance.
However, every flush machine I know of, mine included, does NOT reverse the flow of the fluid. They cant. The machine uses the pressure AND DIRECTION the fluid flows from the transmission. The machines themselves dont generate pressure. Both of those conditions would be detrimental to the transmission because the engine has to be running in order to flush the transmission. The transmission uses that energy to rotate its own pump in order to circulate the fluid through the flush machine. Without the engine running, it is impossible to flush.
treesloth
09-28-2015 07:03 AM
