Doesn't start sometimes
Well I've had this problem for a while and I'm wondering if anyone else has it. When I go to start it with the clutch fully depressed it will sometimes hesitate and fail to start. What's that about?
Nobody?
Kind of hard to diagnose without more information
Originally Posted by 5spdftw
(Post 7761944)
I have had 2 instances in the last couple years where I thought I had my clutch depressed all the way and turned the key... and nothing. I simply took my foot off the clutch and pressed in again, this time being sure I fully depressed it and viola, engine roar. I think I must've "limp footed", for lack of a better term, it both times. But both simply did not crank. I did not have any starting problems once the starter was engaged. Don |
1st thing is to test your battery, thats always the 1st place to start. Next thing that comes to mind is the neutral safety switch.
Yea, more info.
Does it turn over but not 'start'? Or does it not even 'turn over' when requested to by the ignition switch? It could be a multitude of problems with the info so far provided. PATS Clutch Safety Switch FPDM Crank Sensor and the list goes on and on such as is there a proper amount of fuel when this problem arises and does the insertion of fuel in the fuel tank usally make the problem go away are you giving the engine a CHANCE to start by holding the key in the start position LONG enough for the PCM to start producing sparks and injector pulses ????? |
(Post 7761944)
Another question, do you have an aftermarket tune? If so, try asking your tuner to retune for the start-up parameters. Maybe that might eliminate hard start/non-start issues. Other than that, just like the others said, there could be many more issues at hand. |
Even when I make sure that I have the clutch fully depressed it will do like half of a start and then stop. It never gets started when this happens so there's no idle problem. All I do is let the clutch out and do it again and it starts up no problem. Its not a super serious problem but I was just curious to know what caused it and if anyone was having similar problems.
(Post 7765926)
Don |
(Post 7761944)
| All times are GMT -5. The time now is 12:17 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
