Well I managed to get that bolt on started her up and after 20 mins it started making this noise only when I rev it from 2000 to 3000 rpm. I reused my old gaskets and bolts what could be making this noise. Thanks
I would loosen the bolts on the connection from the mid pipe, center the pipe, tighten slowly by tightening the bolts in a unison. If you leak is around where the header meets the head, you will need to tighten the header or get a different gasket.
Look around the headers and pipes and make sure it is not hitting somewhere. Headers often times hit other vehicle parts.
Thanks guys I deff think its coming from the header because I hear it more from the top of the engine then underneath would a exhaust shop be able to fix this or should I take it to a mechanic
