Clutch Replacement Suggestions? Any Stories?
Old 12-20-2011, 03:21 PM
lil_sixer
lil_sixer's Avatar
I have heard a lot of people running Fidanza with the exedy but I am just not sure or dont know a whole lot about flywheels haha
What is machinizing a flywheel now?
sorry for all this question guys,just never really dealt with problems like this..
lil_sixer is offline
Old 12-20-2011, 05:39 PM
Diabolical!
Diabolical!'s Avatar
Machining just means having a machine shop turn the flywheel so that it's smooth again.
Diabolical! is offline
Old 01-01-2012, 08:25 PM
lil_sixer
lil_sixer's Avatar
You think using the stock flywheel would be good?
This flywheel in newtakeoff sounds like a good deal. I just dont want to mess anything up.
http://www.newtakeoff.com/mustang_gt...nsmission.aspx
Old 01-01-2012, 11:35 PM
Diabolical!
Reusing the stock flywheel is fine as long as it is in good condition and you get it turned. Just be sure the clutch you use is compatible with the stock flywheel. Most are, but a few aren't.
Old 01-11-2012, 12:14 AM
lil_sixer
lil_sixer's Avatar
Thanks everybody!
Put the new clutch in by FORD
Went with the exedy clutch and flywheel from newtakeoff,it is soo much more different than stock,Love it!
Stealership only charged $428 which is not expensive compared to the other places!
Old 08-11-2013, 01:01 PM
Pitchblack7720
Pitchblack7720's Avatar
How you know if a clutch is compatible with a flywheel? I got exedy clutch and spec flywheel and its causing clutch drag and high rpm lookout. I just now put a spacer behind the slave cylinder and it made the shifts smoother, still got lookout... =/
Pitchblack7720 is offline
Old 08-12-2013, 11:15 AM
hollywub
hollywub's Avatar
First, call Paul or Lee at McLeod 1-714-630-2764
Buy a stock weight flywheel. Anything lighter is annoying to use in traffic.
I have a McLeod billet aluminum flywheel and RST Dual Disc that I upgraded to ceramic discs (little better quality supplier than Mcleod) and it is a nightmare in traffic, but handles 600+ rwhp with no issues.
I would match the flywheel to the clutch maker, they can be around an 1/8" off on disc design.
Exedy is pretty decent quality as well.
Take whatever your hp goals are and exceed them by 20% with your clutch and flywheel choice.
And change your hydraulic throwout bearing.
hollywub is offline
Old 08-12-2013, 09:03 PM
dlazrael
dlazrael's Avatar
exedy doesnt COME with the TOB, it comes with a pilot bearing. I just got an Exedy 500 clutch set. I did however buy the higher upgraded version of exedy's TOB vs a factory replacement.
dlazrael is offline
Old 08-13-2013, 09:01 AM
Pitchblack7720
Ok, can I just change the flywheel and keep the clutch so the brands match, or is it wise to just change both clutch and flywheel? the clutch and flywheel are still "new", changed them both a few months ago.
Old 08-14-2013, 12:15 AM
hollywub
hollywub's Avatar
It is amazing how many clutches out of the box even with matched parts need to be shimmed.
I just suggested matching because the inside of the flywheel is sometimes smaller than the inside of the clutch disc...
hollywub is offline
Quick Reply: Clutch Replacement Suggestions? Any Stories?
