Tax refund! What do I buy
Hey guys my mustang is 100% stock(performance wise). Its an 08 Mustang gt. I have about 2k to spend. Id love to make my car run fast down the 1/4. Whats my best bet for around this budget. I can install some simple stuff myself, but something like rear end gears I would need to bring it in. Keep that in mind
Thanks
Kevin
Thanks
Kevin
Depending on what kind you get. Polyurethane bushings will transmit slightly more road noise/feel than the stock rubber bushings. Rod-end LCA's are loud as hell, but they are the most beneficial at the strip.
If you only have $2,000 and you'd be comfortable swapping your driveshaft, I'd get gears, driveshaft, tune and intake. You might still have money left over for LCAs after that.
If I was doing my car again, I'd probably hold off on the LCAs. I guess that depends on if you will go to the track. I've never been and it is hard to find people to race me from a dig on the street.
edit: you might even have enough to do those mods and have the shop install your driveshaft the same time as the gears and save a few bucks
Thanks
Kevin
Thanks
Kevin
Yeah its an auto. I drive about 6 blocks back and forth to work in the city, would a toque converter be hard on my engine? Always revving it up high? What is a DR?
