P springs...need anything else to go with them?
I'm looking at some Motorsport P springs for my car because I want to lower it just a touch (especially in the back).
Will I need anything else with these, if I were to install all four? Or is it a small enough drop I don't need to mess with anything else on the suspension?
ghunt,
First I would like to say great decision on making suspension your next mod! You will benefit from this in may ways, handling, stance, traction, wheel hop, ect....
Technically speaking you can just throw some lowering springs on your car and drive it. Depending on how many miles are on the suspension will play a factor with your "ride quality".
A lowering spring can blow out your stock struts in some cases. Mainly with cars that have high mileage, Because the stock suspension is used to your stop spring rate. So down the road you may have to go with a strut and shock set up.
Caster camber plates come into play when lowering a car more then 1.5inches. Anything less then that just an alignment would be fine.
I hope this helps, hit me up if you need any further assistance.
-Dan
