Speed bleeders question
Going to replace my pads with a set of HPS and flush the system using a set of speed bleeders. My question is do you typically leave the bleeders in place or put back on the OEMs once the job has been done since the others can be prone to leaking. Also, what brake fluid do you guys like? Thanks for the advice.
They speed bleeders are meant to be left in place otherwis you will have to rebleed the brakes when you swap the bleeders back to OEM, defeats the purpose.
Dot 3 is OEM, you can mix Dot 3 and Dot 4 although I would recommend flushing the Dot 3 and replacing it all with Dot 4. Higher boiling point, less prone to brake fade in high temps like Texas and AZ and high traffic/stop/go driving.
Do not mix Dot 5 with either Dot 3 or Dot 4.
musnicki
09-23-2015 07:11 AM
