The lower the fog lamp is to the road, the more effective it is. I'd go for the lower fogs as primary if it was me. But you can always change things up.
Already on this; I'm pretty sure the places I'll be where I'll be using them I'll be fine. Rousch Msutangs already do this? Is this something I should look into?
Roush wires so both fogs cannot be on at the same time,
wired to Roush specs, that is.
Originally Posted by 3.73-11
As for wiring you would need another harness or splice into the existing one, or just tap into the side markers and then whenever your lights are on your lower fogs would be also.
If you do the splice thing, use a relay to handle the extra load of the fogs.
Dont just 'tap' them into the side markers or whatever...
Originally Posted by Craigotron
I'd be tempted to swap the already there fog lamps in the grill with ambers and then augment down below. This strikes me as a good solution.
This will just illuminate the fog and make vision worse.
UNDER the fog is where you want the yellow light.
