Clutch wont disengage
I have a 2008 Mustang GT. I was driving today and went for 2nd and it wouldn't come out of gear easily. Put the in neutral and coasted til i could park it. I cannot get the car into with the engine running. Engine off i can put it into a gear. I can start the can in a gear and drive without the clutch but the start is pretty violent any ideas of how to fix this?
Stock everything. No leaks that I can see.
When this happened, the clutch pedal actually stuck to the floor. After pumping the clutch a few times the pedal feel went back to normail, but now the clutch wont disengage.
I suspected slave cylinder at first, but didn't think so since clutch feel felt fine after pumping the clutch pedal... Any other ideas?
I was hoping for something simple I might be able to do before going out and buying parts and trying to replace stuff.
Unfortunately I don't have the tools or location to do this kind of thing at sooooo dealership here I come :-\
Any guesses on cost for something like this?
I might just go ahead and swap out the clutch, flywheel and cylinder slave with exedy parts.
suck... that's what i'm beginning to realize from all the other threads i've been reading.
The mechanic told me all of the material was missing on one half of the clutch disc.... Interesting...
So i put in an order with Brenspeed for an exedy Mach 400 clutch and their steel flywheel. Ive been seeing a lot of good reviews for that setup.
Well it must have welded itself to the flywheel or pressure plate.
So I got the car back and the clutch pedal was losing pressure over time and I had an odd hiss when in 1st, 3rd or 5th.
So I gave up and I went and got a 2013 GT premium with the brembo brake package :-)
