120mph=Hood vibrating
Just got my gt a couple of weeks ago and i was testing it out lol. and doing about 120 the hood was vibrating pretty bad almost looked like it was about to fly open. would hood pins help? has anyone else noticed this?
thanks
thanks
Hood shake is pretty common on the S197 as Diabolical! states. You can adjust the bushings on the left and right front corners by adjusting the one side (first) that seems to be the worst (unless both sides are shaking bad) about 1/4 turn up at a time. I was able to eliminate mine that way. Others have resolved it by putting one-sided tape insulation above the headlights to reduce the amount of airflow getting under the hood and causing the lift.
Anyone know if the 2013 GT vented hoods eliminate or at least mitigate this problem? Planning a day trip to Summit Point in W.V. and don't want to have the hood fluttering suddenly start up when going down the straightway at 100+...
