trumpeting with pypes mid muffler and stock H?
I don't have the pypes bombs axle back. I have the mid mufflers with stock h pipe. It is straight pipe from before the axle all the way back. Having the whipple on there effects the exhaust as well.
I thought about getting the pype bombs, but since I all ready have pipes running all the way back where the stock mufflers go, all I have to do is cut them and add resonated tips. If you just have an axle back, then you'd still have to fab up some pipe going to the over axle pipes.
I'll post a new video from the same location, hopefully this weekend. It really only makes that sound in 2nd gear at mid rpms and half throttle or so.
I should get the new tips today, but not sure I will get them installed right away. I have a pinion seal to replace now.
I found that my drivers side rear most hanger had slipped out of the rubber bracket and was intermittently contacting the metal part of the hanger! I had to remove the hanger just to get it back in place. I really surprised it wasn't making any chirping noises.
I was also able to turn the whole drivers side pipe at the H pipe connection, even though I had it torqued to 35 ft lbs, wtf! I tightened the F out of it this time.
alright, I cut about 8 inches of pipe off the muffler delete pipe that comes with the mid muffler system. I now have only the one hanger after the axle, but it doesn't seem to matter, these tips aren't that heavy. Here's a video. I left it a little long in the middle so people could see how bad my road is after it rains.
WOT in 3rd is at 3:33, but I couldn't hold it very long, because of a stop sign coming up. It definitely sounds different.
This isn't a truly fair comparison as I have a different tune on the car now, but the trumpeting was there with both tunes. Here's the mid muffler with the short pypes tips.
The tips are cheap, $53 for the pair. As you can see it's just a hollow 4 inch tip with a resonated core shoved in it and spot welded on the other end. I'm curious how it would sound with some hollow 3 inch tips.
These tips were not clamp on, I cut 4 slits in them using a grinder with cutoff disc.
I'm going to give it a few days to break in. I'd like to try some longer hollow tips to compare, but that's another $50. It is noticeably quieter at idle, which is ok with me. The real test will be this morning to see if it wakes up my wife.
I'm sure I could get these and resell them if it doesn't sound good.
http://www.ebay.com/itm/QTY-2-UNIVER...sories&vxp=mtr
