cant bleed the brakes 05 GT
Not sure if this will help or not. I had the same problem with an 05 Chevy pick-up. Finally found something online that basically said to drive down the road and slam on the brakes a few times. After that they bled fine. Had something to do with the ABS system. Might give it a try if you can't find any other remedies.
I tried that earlier today, with bearly any brakes. IE really spongy brakes. No dice.
I found that If I used my DIY pressure bleeder at the wheel cyl. I get a much frimer peddle. I will try activating the ABS again tomorrow. and will report back my findings. As much as I hate to say it, I am going to have to most likely take it in to the shop.
Matt's 95 Stang
10-05-2015 07:16 AM
09-25-2015 06:42 PM
