Replacing whipple heat exchanger?
No problem. Now can someone tell me if I need to bleed the air out of the heat exchanger? I've been googling it and still not sure. Correct me if I'm wrong, but my thinking is I can squeeze the hose coming out of the HE to help push any air out of it.
how do you have it run? I've always read the whipple instructions actually have you do it backwards, you should fill the heat exchanger from the bottom, thus eliminating possibilities of bubbles.
Did a whipple install on a buddies car like 3 months ago and I swear they had you "fill" it from the top, which seemed backwards.
Coolant just passes through it, so why would there be a "set" inlet and outlet?
Just passing along info from people that have re-routed theirs with benefits, and no more worries about bubbles.
I mean doesn't it just make sense that if you're filling something with a fluid, you would fill from the bottom?
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
