pacesetter long tubes
Hey guys I recently put 39 pound injectors in and pacesetter LT headers the car ran with injectors only. After putting in the long tubes it ran rough. Changed oxygen sensors wouldnt even start. Swapped old o2s back in still wont start at all. Check engine light blinks but has no codes.... This is all trying to run it with open header. Gin to bolt on a makeshift exhaust tomorrow see if having the o2s so close to outside is causing it on the upstream side other than that anyone got any ideas on what could be the problem.
OP,
You're going to need the PCM calibrated for the larger injectors, like moosestang mentioned. Otherwise the fuel trims will be completely out of whack. That's probably why you aren't able to get the car to start.
Any customer tuner will with a reputable tune should get the job done!
Shane
Shane
yeah, if it's not tuned for the larger injectors, then it would be subtracting fuel like a mother or would it be adding? It'll be messed up, that's for sure.
Try holding the accelerator down while cranking to clean the plugs, then try to start it without holding it down. This would only be a temporary fix, but will tell you if the plugs are fouled.
I wonder what your start up air fuel ratio looks like. I bet it's either really, really lean or really, really rich.
Its rich. It ran for a while the computer adapted to just the injectors but I reset the ecm while putting headers on and now I think the computer is confused as ****. It ran for a while with it but it doesn't want to do **** now lol tune date is march 15 with hpp gonna go ahead and put cams in while I wait
Shane
Shane
Yep it goes to the dyno shop on march 15th. Im reinstalling injectors doing stage 3 vsr comp blow cams valve springs and phaser. Ill let them do a tune before they start it then they can tweak it but it wont be driven till then.
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
10-05-2015 07:40 AM
