Dissappointing HP #'s '12 5.0 Steeda CAI & 93 tune
Old 06-02-2013, 08:49 PM
SpartaPerformance
SpartaPerformance's Avatar
I'm not saying you're bragging etc... It seems we're all too fixated on numbers. On a dyno all you need is a pin straight A/F so you know you're making max power. That's what counts.
SpartaPerformance is offline
Old 06-02-2013, 09:56 PM
joe95 gt
joe95 gt's Avatar
Originally Posted by ski
You're ok.
DynoJet results are normally 10% higher than a Mustang dyno.
10% really I read in an article that it was 6-7%
joe95 gt is offline
Old 06-03-2013, 08:25 AM
awbreyjd
awbreyjd's Avatar
Take it to the track and check your mph. That will be a true test of what it makes.
awbreyjd is offline
Old 06-03-2013, 08:49 AM
ski
ski's Avatar
I've seen 10% on a few comparos between those 2 dynos.
ski is offline
Old 06-07-2013, 03:43 AM
drewsky
drewsky's Avatar
Don't forget. We don't race on dyno meters we race at tracks or the street.. For instance gears will not help ( if not hurt) dyno numbers but make your car faster, I try to explain this to people all the time when this comes up.. Driveshaft upgrade as well. Dyno's are for tuneing purposes only not to see who has the biggest whatever. And also IF it was a cooler day your numbers would rise! AND all dyno's run different.. Don't be upset, your car is fast!
drewsky is offline
Old 06-07-2013, 08:54 AM
awbreyjd
awbreyjd's Avatar
my car dynod 30hp more on 3.31 gears than it did on 3.73 gears. But at the track the 3.73 gears were almost .5 seconds faster. As stated above dyno's are for tuning purposes only. Track it, see what MPH you are running and that will be your best test.
awbreyjd is offline
Old 06-07-2013, 01:12 PM
ski
ski's Avatar
Weather conditions should not cause variations in the numbers if an SAE correction factor is used.
ski is offline
Old 06-07-2013, 03:41 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Without a baseline number (STOCK) run to compare against, you really have no idea how much YOUR car picked up. also, what's the A/F graph look like?
Derf00 is offline
Old 06-07-2013, 07:51 PM
MrSandman
MrSandman's Avatar
Was it a 5th gear pull? Mine did 389 stock... and then again.. 389 a year later with the FRPP tune.. so at least you had gain. The only thing I gained with the FRPP tune was detonation.
MrSandman is offline
Old 06-07-2013, 10:18 PM
808muscle
808muscle's Avatar
This^^
MPH will tell you all the power you have. ET is determined by driver.
808muscle is offline
Quick Reply: Dissappointing HP #'s '12 5.0 Steeda CAI & 93 tune
