Stumbling while idling with CAI? Anyone had this?
Old 07-06-2013, 05:01 PM
mapitts
mapitts's Avatar
Will a low fuel pressure condition set off a CEL? Either with the pump itself or the fuel pressure regulator?
mapitts is offline
Old 07-06-2013, 05:19 PM
Lifter583
Lifter583's Avatar
Originally Posted by BleedinBlue
Only nailed for the 57,106'th time this year, too! No doubt the #1 "What's wrong with my car?" question here.
Thats for sure!
Lifter583 is offline
Old 07-08-2013, 01:47 PM
dlazrael
dlazrael's Avatar
Originally Posted by Nuke
I'd pull the TB off one more time and give it another cleaning, just to be sure. Otherwise, try one of your other tunes, although I truly doubt it's the tune. When was the last time (mileage) you cleaned and recharged the Steeda CAI?
Ill have to pick up some more TB cleaner and do this again. It's done it on all three tunes, so I am sure its not the tune (the 87S, 91P and 91R - all from BAMA); I've never cleaned / recharged the steeda filter, but its only been on the car maybe 4-5 months... I might have to try that. I'll check steeda's site for the kit for it. Thanks for the info
dlazrael is offline
Old 07-08-2013, 01:56 PM
dlazrael
dlazrael's Avatar
Mileage would be around 7k
dlazrael is offline
Old 07-08-2013, 04:52 PM
Nuke
Nuke's Avatar
Even if you had that full 7k miles on the air filter, it shouldn't need to be cleaned for quite some time unless you're driving on dusty dirt roads all the time. The only other thing I would do before troubleshooting further would be to run 1 or 2 tanks of SeaFoam in case it's injector related. Although I typically add Techron to the tank every oil change or 10k miles (whichever comes first), I save the SeaFoam for when I believe I have an issue with any of our vehicles.
Nuke is offline
Old 07-08-2013, 04:57 PM
hootie_john
hootie_john's Avatar
Don't forget to check/change the fuel filter. The manual says 30k I think, but at 20k, mine poured out what looked to be coffee when I changed it.
hootie_john is offline
4cylinderplus2
10-09-2020 07:45 PM
baddog671
07-26-2016 01:20 PM
TCStangerv6
10-11-2015 05:57 PM
svfetter
10-05-2015 11:39 AM
junior04
09-28-2015 10:53 AM
Quick Reply: Stumbling while idling with CAI? Anyone had this?
