CAI install with aftermarket ram air hood?
Hello all,
Just had a Cervini concept ram air hood put on my '05 GT. Also installed was the ram air kit which has the ducting on the hood and the snout that is mounted to the stock airbox. I am trying to figure out if I can add a CAI to the car with an aftermarket hood. It appears that the plastic "box" on the CAI units must be made to contour the stock hood so not sure how it would work. I am thinking that because of the ducting, the hood may be lower and would hit the CAI "box". Has anyone tried to do this? Perhaps you can trim the height of the CAI box?
Seems like the ram induction hood along with a CAI would be a great improvement, just don't want to spend the money if it would be a huge project to make it fit.
Thanks,
John
Thanks,
John
Try calling AM or Brenspeed and see if they're familiar with that setup. Personally, I don't believe that you'll see any additional gain from the ramair setup if you had an existing CAI & tune. The additional airflow under the hood may help a bit with heat soak problems that these S197's are so noted for, though.
You would have to do major surgery to use the Cervini ram air kit with a CAI. Believe me I tried it when I was using a Steeda CAI. Figured just getting some cooler outside air in the general vicinity of the CAI could do nothing but help because the Type IV hood I have does not even come close to sealing against the top of the CAI shield (now an Airaid). I let the scoops just ventilate into the engine bay but I have considered cutting off the funnel part of the ram air duct so that it just directs air toward the CAI general area.
Quick question, when you installed the CAI with the ram air kit installed, did your hood (or rather the ram air duct) then hit the CAI or would it not seal against the ram air duct? Just curious what the initial condition is with both items installed intact.
Just noticed that your hood is different, mine is the concept hood that is more flat with the scoops recessed so my hood would be lower to the engine if that would matter..
THanks,
John
THanks,
John
The ram air duct hit the CAI shield. Tried trimming the shield but it still interfered. Kept doing that until it got to the point that there was not much more I could trim. I believe all of the ram air ducts are the same no matter which hood you have. Yours might hang down even further with the concept hood. It is the "funnel" part of the duct that is the problem.
inyadreems
08-21-2015 09:10 AM
