17x5 Skinnies over Baer 6P Brake Kit
Old 09-03-2014, 04:51 PM
crazy50
crazy50's Avatar
Default 17x5 Skinnies over Baer 6P Brake Kit
Well I'm hoping people might have some insight on this. I ordered some Weld 15 inch rims/slicks for track. I want to order a matching pair of rims/skinnies for the front of the car but the calipers are huge and I'm not down grading.
So my question is this..
These rims have a 2.2" backspace, can I add a 2" Spacer and clear the Caliper? Is there ANYTHING I can do to get a legit skinny on front without changing the brakes?
These are the actual rims if it helps at all
http://www.americanmuscle.com/weld-r...17x5-1114.html
2011 Mustang 5.0
crazy50 is offline
Old 09-04-2014, 06:46 AM
Scott2
Scott2's Avatar
17" Racestar skinnies fit over my Baer 6P's with no spacers, but 3" studs.
Scott2 is offline
Old 09-04-2014, 09:29 AM
AMDanBailer
Former Sponsor
AMDanBailer's Avatar
2011 Mustang 5.0
^ This!
They should fit fine. Most skinnies fit over Brembos and large brakes.
I would go with a 17x5 and you should be in good shape. You can also feel free to hit up Weld directly. They're very knowledgeable on their Wheels and can answer any questions!
-Dan
AMDanBailer is offline
Old 09-05-2014, 02:11 PM
crazy50
crazy50's Avatar
Thanks fellas. I contacted Weld Racing as suggested and spent nearly a half an hour on the line with Gayle. Ultimately she said that I needed an 18x5. I wasn't aware they made bigger skinnies but Summit Racing had the rim I wanted in an 18x5 with the correct offset, etc.
I appreciate the help!!
crazy50 is offline
10-07-2015 07:02 PM
Gonzo71
06-23-2006 09:07 PM
David_K
17
03-09-2006 10:13 PM
winslow
03-01-2006 12:34 PM
jw
02-16-2006 08:19 PM
Quick Reply: 17x5 Skinnies over Baer 6P Brake Kit
