Procharger advice!
#21
If you are looking to make around 700hp with a 3v, you better have a fat budget. If I were you, get the spec's for the ford racing aluminator 3v motor and copy that.
#22
normally im against twin screw blowers (they like to heat soak and run like pigs) but considering your 2011 likes to make good power in the high rev range that twin screw will help you on the low end for nice even balance here we have a 2014 with a tvs blower making realllly nice power id go with that TVS....but you cant go wrong either way boost is boost ;-)
what blanket statement??? i said twin screws have heat soak issues.... haha they do.....and when they get warm they make the car run like a pig.....this is from personal experience. Yes some are better then others and i am by no means saying ts blowers arent good im just saying. I think centri is gonna make wayyy more power on car on the street(anywhere but on a drag car) comparable blower to comparable blower and that was the case on my personal car...
least we can all agree turbos are king tho ;-)
#23
Sactown would know. You will need good heads, cams and long tubes, plus a great intake manifold, a good tuner, fuel system that may or may not be custom depending who you know has done it before and great cooling for the blower and the engine.
It's not cheap.
Dragonus18
09-09-2015 01:21 AM
