4.6 stroker kit?
My comment was geared mostly towards cams, which in my opinion make no sense considering the HP gain to cost ratio.
also, once you open an engine, reliability goes out the window. If my engine ever dies I'd rather make a used Coyote conversion than get a built 4.6
4.6 stroker kit ?
mericumm, as far as I am concerned, the 4.6L, oem, is over-stroked from the factory. It is-what-it-is. Make the upgrades Dino suggests and have fun.
Flash xx is correct about not putting a lot of money into this project.
4.6 stroker kit
mericmm, everyone here is on the money. The best way to make the 4.6 come alive,especially on acceleration, is to do what Ford did, bolt on a supercharger and never look back.
As FLASH XX said, it is expensive, and like Deno said, there are other, more productive options to take.
Let us know what your decision is and everyone will pitch in to make it a winner.
Regardless as everyone has said getting into the internals of the block and the rotating assembly is for those trying to make serious power thought boost... which means serious money.
4.6 stroker kit
danzcool, you caught me putting my cart before the horse. Somehow I got caught up with "rod to stroke ratios" and applied the wrong math to my answer.
Thanks for reminding me, very gently, to keep focused when answering a question.
The advantages of lengthening the engine's stroke are that it can produce more torque especially at low/medium rpm, and the increased compression ratio improves thermodynamic efficiency and fuel economy. Stroker kits also come with a forged crank, rods, and pistons which you'd need if you wanted to add FI later on.
The disadvantages of stroking the engine are that you're adding displacement without improving the engine's breathing so unless you do the latter, the gain in high rpm torque may be minimal to none. Thus you'll find peak HP & peak TQ occur at lower rpm, with a higher % torque gain at lower rpm. The longer stroke also increases the piston speed at any given rpm, thus reducing the safe maximum operating rpm.
Someone recommended just getting an 2013 F150 Coyote, which you can get for less than 3k complete. Makes less power than the Mustang's but has a a bit more torque down low. It even bolts to the TR3650 trans, so that might be the way I head. Only differences are the manifolds and cams and the manifolds don't matter since I'll be putting headers on. Still makes way more power than a N/A 4.6. Getting gauges to work is going to be a pain though.
