Is my exhaust aftermarket?
Old 08-06-2018, 05:06 PM
BroncoMarc
BroncoMarc's Avatar
Default Is my exhaust aftermarket?
I've got a 2011 GT with just under 36,000 miles and my H Pipe is rusting out. I bought a Ford Motorsports X pipe to replace it and it does not fit!
If I bolt it up to the pipes from the cats, then the back of the X pipe does not land at any junction. The back of the X-pipe is actually right at the crossover tube of my current H-pipe. Another thing I noticed was that the X-Pipe I bought is 2.75", but the current exhaust is 3"
Here are pics: https://photos.app.goo.gl/5Z6Ncwej3rTch3QF6
I bought the car used with less than 9000 miles on it, and it sounded like a factory exhaust. I added a Rousch axle back which made it much louder (and it bolted up with no issues).
Am I going to notice any performance loss if I downsize to 2.75'? Does anyone sell re-make pipes to go from the X-pipe to my current axle back?
Thanks,
- Marc
BroncoMarc is offline
Old 08-14-2018, 04:45 PM
Coosawjack
Coosawjack's Avatar
Hey Marc......OEM exhaust is stainless and would not rust out like that.....so that is aftermarket or home made!!
I have a spare MRT 3" "H-Pipe" I'd sell ya but you already bought the X-pipe.......lotsa SS over axle pipes available that should get ya fixed right up!!
Good Luck!!
Coosawjack is offline
Old 08-14-2018, 05:25 PM
BroncoMarc
BroncoMarc's Avatar
Thanks for the reply. I actually stopped by a speed shop today and they confirmed it was aftermarket. Strange that is the only aftermarket part on the car, and it had stock mufflers!
I'm now searching around for a stock mid-pipe. The speed shop said I wouldn't notice a difference going from 3" to 2.75. They said they've put 900 HP thru the stock exhaust.
- Marc
Old 08-15-2018, 10:45 AM
Coosawjack
Coosawjack's Avatar
Did they cut the ball flanges off of the down-pipes with the cats?? If not, I have the MRT Mid-pipe (H-Pipe) I'll make you a deal on!!
Old 08-15-2018, 12:19 PM
BroncoMarc
BroncoMarc's Avatar
Looks like it's all bolt-on. I just want to replace everything from the cat pipes to the muffler since they used cheap aluminized tubing that is all rusting now. I've already got the X pipe.
- Marc
Old 08-15-2018, 01:10 PM
Coosawjack
Coosawjack's Avatar
Double check the connections from the cat pipes.......they should be rounded "Ball" type ends to fit into your "Socket" type connections on the X-pipe using a special clamp that pulls them together for a good seal!! Hopefully the previous owner didn't cut them off but it sure looks like maybe they did??
If so perhaps your muffler shop can re-flare them to accommodate your X-pipe??
Also keep in mind an X-pipe can make your exhaust very raspy with certain aftermarket mufflers!!
Good Luck!!
CrzyHrs
01-16-2013 06:16 PM
Apollos2
24
06-19-2009 09:46 PM
explict
02-23-2008 04:04 PM
Black on blacK
05-23-2006 01:57 AM
Bob99GTConv
09-16-2004 02:20 AM
Quick Reply: Is my exhaust aftermarket?
