AUTO METER SHIFT LIGHT HOOK UP INFO
Passenger side of car locate the power distribution box.
Unsnap top half of Power distribution box. Find under the GREEN box port C5. (2 larger solid red wires coming out of same port). Do not use smaller solid red wires.
(Do Not use F6).
Follow wires out a few inches and cut both. Twist together the 2 RED wires coming out of the power distribution box then hook them to the RED wire coming from the 9117 tach adapter.
Then twist the remaining 2 RED wire ends from the wire harness together and hook them to the RED w/Green stripe wire from the 9117 tach adapter.
The GRAY wire from the 9117 tach adapter hooks to the GREEN wire on the 5310 RPM Module.
The RED wire from the 5310 rpm module goes to power.
The BLACK wire from the 5310 rpm module goes to ground.
The Green wire hooked to the GRAY wire on the tack adapter.(tach signal).
Plug in 5331 lite to the RPM Module.
Info came from Auto Meter Tech ....................
(Do Not use F6).
cardsrus1
19
09-15-2015 08:37 AM
09-01-2015 08:16 PM
