CLutch Pedal
Old 08-19-2018, 03:34 PM
MNKYBZNZ
MNKYBZNZ's Avatar
Default CLutch Pedal
Clutch pedal went to the floor, stuck there. Could not shift into any gear. Coasted to stop off the road. Reached down, pulled pedal up, and has worked fine since. What could have pissobly happened, something wearig out? Only have 26000 on my 14.
MNKYBZNZ is offline
Old 08-21-2018, 05:43 PM
08'MustangDude
Banned
08'MustangDude's Avatar
Well, you don't have a cable, so...
If the clutch pedal will not return or is too low, then the system has a leak and
must be repaired and then bleed the air from the system. The slave cylinder
could be broken too.
08'MustangDude is offline
Old 08-22-2018, 05:15 AM
Dino Dino Bambino
Dino Dino Bambino's Avatar
Sounds like a failing clutch master cylinder.
Dino Dino Bambino is offline
Old 08-22-2018, 05:52 AM
GT Nate
GT Nate's Avatar
dirt perhaps in the cable, or possibly a torn spot in the cable which is catching the wire as it returns? See if a shop can put it on a lift to get a good look at it, maybe one guy can sit in it and push the clutch in and out to see if it binds or is in the clutch itself...I can't imagine the clutch fork being the issue.
Good luck amigo
GT Nate is offline
Old 08-22-2018, 06:28 AM
08'MustangDude
Banned
The 2005, S197, Hydraulic Clutch, has a CABLE?
Old 08-23-2018, 04:33 AM
Dino Dino Bambino
The clutch is hydraulic Nate. There is no cable.
It's quite likely that the piston inside the master cylinder got stuck, and the OP managed to free it by pulling the pedal up. If it happened once it'll happen again. You just don't know when but Finagle's Law says it'll happen at the worst possible moment.
NewEdgeStang00
06-24-2014 08:26 AM
partsguy329
07-24-2011 02:46 PM
kickn4macon
09-26-2008 07:40 AM
6t9 stang
03-17-2008 03:22 PM
joeybutts
08-01-2006 08:36 PM
Quick Reply: CLutch Pedal
