Adding a supercharger to my 05 vert.
Ok,
I've talked myself into the ATI Procharger for my 05 vert. So far I've done the C&L intake with the XCAL2 system, 4.10 gears, Steeda Underdrive pulleys, Mac axle back exhaust.
Some people have mentioned the need to do engine mounts which makes a lot of sense and also doing the rear end. What needs to be done to the rear end if anything and
if something is needed, how much will it cost? Thanks.....
RE: Adding a supercharger to my 05 vert.
Are you talking about your bottom end if so then you will only need that if you want over 500rwhp. With the Procharger you can kiss the underdrive pullies and your C&L goodbye. You can still use the 4.10's but 1st gear is really wasted. Install on the Procharger is 10-12 hours for someone with experience.
ORIGINAL: clubt
Some people told me that the drive shaft or axle would not handle the sc??
The axle on the new stang is actually one of the best features the car has. Although I can't imagine why Ford wouldn't spend the extra $0.20 to coat it so it wouldn't look rusty all the time...lol
Truth of the matter is you cannot do anything to the factory motor that the axle cannot handle. If you go over 500RWHP, then you should look into the drive shaft, but I doubt you'l even need to do that with the procharger unless you mod for major boost.
[IMG]local://upfiles/24802/2DE1530BB3214C9D89A499D88CEEA29D.jpg[/IMG]
Gotta disagree with you there C.K. Mine is in the shop right now. I had a 100 shot of Nos on it and my rean end got toasted.[X(]
ORIGINAL: chevykiller
ORIGINAL: pcdrj
Fin1,
Noticed you have Steeda suspension upgrades. Did you consider Saleen or Ford Racing? How does your suspension do in the twisties?
Fin1,
ORIGINAL: toolttime
Why use underdrive pulley's when you have a supercharger??? Duhh wouldn't that make the s/c turn slower??
10-05-2015 07:40 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
