C&L True flow kit
C&L True flow kit
Has anyone who purchased and installed C&L True Flow cold air kit had any negative isues with it? Anything from fittment problems to driveability problems? I was looking to purchase one possibly and wanted to know more info from people's experiences.
Thanks
Thanks
RE: C&L True flow kit
It took me 30 minutes to install and abuot 15 mintues to put the tune in. There is a big difference, mostly with throttle response. Car feels a bit quicker probably by half a car length or a bit more. The only problem I have had is that it seems with the 93 octane tune, if you get bad gas, as I have done twice, and you downshift to take off the engine hesitates big time. But, that really isn't a problem with the tune, it's a problem with the gas in Alabama.
the biggest benefit is the throttle linkeage problem you have now is almost totally corrected in first gear. It is quicker and it doesn't allow you to redline going through the gears ;it gives you plenty more extra. Also from what I understand that if you have an automatic it really makes the difference. The tune takes about 3 minutes. I didn't install it myself. I had a shop do it for 30 dollars.
ORIGINAL: ScreamingYellow
ORIGINAL: BrookShadow_RC
So with the tune, do you *have* to go to 93 octane? I'm looking at one of these kits as well, but do not want to pay for the more expensive gas, if possible.
