Zex Kit Install
#21
RE: Zex Kit Install
GotYo I just reinstalled my kit and realized I told you wrong. The wire with the smooth casing coming out of the switch is the positive. Sorry I found out after I hooked it up backwards this time. I just got the purge kit from zex last weekend along with a bottle heater. It looks like a fairly easy straightforward install. For the past couple months I have just been leaving it in the lines. If you don't have a purge you can always unscrew the line from the bottl when you close it to reease the pressure.
#22
RE: Zex Kit Install
DRock - I ended up having access to a multimeter so I double checked the polarity and the line with the writing was the positive, so what you told me was right. I had to take the switch out temporarily, but when I put it back in I'll check it again.
I'm going to look into the bottle warmer and purge. The most annoying thing about modding a car to me is running electrical lines. Hard to keep neat, and a pain to do it correctly. Looks like I'll be running some more wire to the trunk.
#23
RE: Zex Kit Install
I'm with you 100%. I mounted the control unit on the plastic box that came with my C&L CAI. There is a hole right at the top of the drivers side wheel well you can run the wires from the control unit through. I went through the same hole that the hood release cable runs through in the fire wall. It hides it pretty well. All I need is to pick up some wire loom and it should look clean. I'll post some pics when I get home if you would like. I am going to go ahead and hard wire the activation swith on the dash when I put in the heater and purge switches. Have you had the dash off on yours yet? Any pointers you can give me?
#24
RE: Zex Kit Install
ORIGINAL: DROCKOFTX
#25
RE: Zex Kit Install
Sounds good I will probably do the same. When I reinstalled it I just hooked to the bottom of that plastic cover with zip ties. It was driving me nuts trying to run it inside of it with no decent lift. My girlfriends dad owns a shop and I am going to use on of his lifts this weekend. I've never installed gears I am going to try to get him to teach me how and put some either 3.73 or 3.90 in.
#26
RE: Zex Kit Install
I need replacement jets for .030 and .046 for the 100 shot.
I tried ordering from Zex.com with no luck. And I can't seem to find where I can get these jets. Any suggestions?
Oh, and would 16' worth of line work from going from the trunk to the engine. I found a local shop that has 16' 4an, but not 18'. And I can't order from Zex.
#27
RE: Zex Kit Install
16' should probably work. I had a few extra feet in the trunk after my install. You can order the jets from zex. go to the web site and search for "jets". The first option takes you to a page where you can order them.
#28
RE: Zex Kit Install
ORIGINAL: DROCKOFTX
#29
RE: Zex Kit Install
ORIGINAL: GotYoNacho
I tried to order from Zex. I'm sitting on Day 9 with an order receipt, no charge on my card, no package (using fed ex 2nd day). No response when I call them. No response from email I sent them. Makes me wonder.
ORIGINAL: DROCKOFTX
#30
RE: Zex Kit Install
Installed my ZEX kit today with the remote bottle opener, almost, I want to run the electrics through the console and in the glove box but don't see an easy way to remove the dash or console to run the wires under. Does anyone have a how to on this?
Thanks in advance!
Thanks in advance!
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-01-2015 08:16 PM
