Negative camber after spring install...
After installing my Steeda sport springs, I have approx. 2 degrees negative camber in front. I have not given a really good look under there yet, so I was wondering if there is anything I can adjust myself to correct that, or do I need to take it to a shop? Is the camber adjustable at all without additional hardware?
My rear axle moved 1/8" to the left, so I'm going to leave that alone.
Love the springs, BTW. They feel good with the stock dampers.
Thanks for any advice.
RE: Negative camber after spring install...
Several different ways to adjust camber. Simplest is a pair of camber bolts for about $20. Steeda sells a camber plate kit for about $190. Finally you can slot out the lower strut bolt holes as outlined in the service manual, cost $0 if you already have a carbide bit. Adjust it back to around -0.5 degrees.
www.summitracing.com is one source. Available where ever fine auto parts are sold.
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
