Stock Gearing
02-14-2006, 02:14 PM
Stock Gearing
Does 2500rpm@80mph sound right for the stock gears?
02-14-2006, 02:16 PM
RE: Stock Gearing
I vote no...if you have the correct numbers. I'd guess 3:55:1 gears..3.27:1 was stock.
02-14-2006, 02:19 PM
RE: Stock Gearing
Actually 3.55 is stock.
02-14-2006, 02:41 PM
RE: Stock Gearing
seems about right. I will check for sure when I hit the highway, but I usually run right at 80 and it is right in the 2500rpm range, and yes, 3:55:1 is the factory ratio in my 5 speed.
I ♥ Acer
RE: Stock Gearing
That sounds about right. Mine turns 2700 at 80 with 3.73s.
On another note the stock gear in the manual is 3.55s, the auto 3.31s.
02-14-2006, 02:44 PM
RE: Stock Gearing
So im getting my 4.10's installed sometime next week, what RPM's will i be looking at aroun 70-80mph. People are saying 2800@80?
02-14-2006, 03:07 PM
RE: Stock Gearing
Without doing the whole equation thing, tire diameter, 5th gear ratio, rear gear ratio and all, I think that 3000 to 3100 rpm is more likely.
02-14-2006, 03:08 PM
RE: Stock Gearing
Quote:
ORIGINAL: TMG
4.10 gears/5th gear
2000 rpms=56.25 mph
3000 rpms=84.37 mph
4000 rpms=112.49 mph
5000 rpms=140.61 mph
6000 rpms= 168.74 mph
02-14-2006, 03:21 PM
RE: Stock Gearing
Cool, i can keep it a 70mph, less likely to get a ticket anyways.
02-14-2006, 03:48 PM
RE: Stock Gearing
You da man Freako!
