Mach 1 aftermarket
lets say I was to get a mach 1, can I use the mid pipe I have on my gt on it? I have steeda pullies NIB can I use those on the mach also? I know I can use my new gears on it.....what about my tune...can i use my tune on the mach?
2 more questions.... what does a mach dyno stock? With o/r h pipe, pullies, k&n and a tune what would it dyno at? and what time should be expected? |
RE: Mach 1 aftermarket
Stock it will dyno around 275 hp
With exhaust/intake and a good tune you will see 300 I wouldn't recommend pullies though...not on a Mach |
The midpipe will convert just fine- all mach 1 midpipes and catbacks are interchangeable with all 99-04 GTs exhaust...headers are a different story. Sell the pullies and get yourself a intake spacer, JLT, MGW, etc. The handheld tuner should crossover as well. I know that my friend with a 99 GTbought his Predator from a 03 mach 1 owner and it worked fine. You should be between 265-280rwhp stock, with some good mods and a tune around 300-310.
If you can steer at all, times should be mid to high13's stock (depending on auto vs. manual). If you're one hell of a pilot, mid to low13's (again, depending)
After full bolt ons and tune, should should flip the lights at low 13's to high 12's, maybe mids if you can REALLY drive. |
270 hp stock is badass.....i forgot to ask how much torque do they dyno? Why no pullies on the mach?
What are the problem with using underdrive pulleys?My car has them and seems to work fine.If i'm losing power then i would can them.
I've heard several members say not to use pulleys. |
ORIGINAL: COMPMACH What are the problem with using underdrive pulleys?My car has them and seems to work fine.If i'm losing power then i would can them. I've heard several members say not to use pulleys. |
What have you picked up on how and why they do that? I'd like to compare notes.
ORIGINAL: groundpounder What have you picked up on how and why they do that? I'd like to compare notes. http://anythingcars.com/forums/viewt...sc&start=0 http://www.mach1registry.org/forums/...hlight=pullies http://www.mach1registry.org/forums/...hlight=pullies http://www.mach1registry.org/forums/...l+Pump+Failure |
Thanks for the info Machwon.
