For those looking for a BA Mach 1....
This is an example of a very well priced, very fast mach 1 mustang. I am posting this up for a buddy of mine- I can tell you this is a very very mean, fun, and clean stang! He let me drive it one time and it is amazing. If interested please contact him (he's a really cool guy) and his number is listed at the bottom. I have personally seen this car do 11s, and then be taken out for a night on the town so its as streetable as stock. Best part is it only has 7K on the odometer! Like I said give him a ring if you're interested in a BA Mach 1!
For Sale: 2004 Ford Mach1 Mustang, 4.6L 32V, DOHC, 7K miles. This car has been professionally modified with the following components:
· NOS dry nitrous system w/100HP shot, RPM activated window switch, WOT switch, bottle heater and blanket, blow down tube, and liquid filled pressure gauge
· Ford Motorsport 42lb injectors, w/adapter harnesses
· NGK TR6 spark plugs, (one step colder than stock plugs)
· C&L cold air intake kit
· New PCM, (Power Control Module)
· SCT XCAL1, with custom N/A and nitrous tunes for pump gas and race fuel, (custom tuning performed by MC Racing)
· MAC 2 ½ Pro Dump exhaust
· Steeda Tri-Ax (short throw shifter)
· Front sway bar removed
· UPR Radius Rod Adjustable Upper Control Arms, w/aluminum bushings
· UPR Pro Race Series Adjustable Lower Control Arms, w/aluminum bushings
· Maximum Motorsports 6 point roll bar
· Paul’s High Performance axle brace kit
· Welded axle tubes, torque boxes, and sub frame connectors
· Paul’s High Performance drive shaft safety loop
· T/A Performance rear end girdle, w/bearing cap stud kit
· Eibach drag launch air bag kit
· G-Tech Pro, (performance meter with built in shift light)
· Front sway bar, rear seat, rear trim panels, and carpet were removed from this car; however, front sway bar, rear seat and trim panels will come with the car.
On the Dyno this car made 288RWHP and 311RWTQ naturally aspirated and 384RWHP and 527RWTQ with nitrous. The car has ran a best ¼ mile ET of 11.73 @ 115 MPH.
I am asking $15,000.00 FIRM for this car. Serious inquiries only!
If interested, contact Adrian at 816-223-2713
Thanks for your help,
Manny
Manny
breaking
10-02-2015 01:27 PM
