are UD pullies bad for a Mach
#22
RE: are UD pullies bad for a Mach
For the amount of performance to be gained, it's not worth the risk. Because the crankshaft pulley is smaller, it causes an out of balance harmonic vibration,and it will fail eventually, especially if you wind the motor out close to the redline on a regular basis. The only true way to be safe is not to install the u/d pullies, or to have a new billett steel oil pump gear installed. And just an FYI, the Mach 1 came from the factory with an underdrive pulley alreadyinstalled for the alternator.
breaking
10-02-2015 01:27 PM
KingRando
10-02-2015 08:06 AM
