who sells MGW sts? - Page 3 - MustangForums.com
Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
who sells MGW sts?
Old 03-30-2008, 10:42 PM
  #21
HamMach1
HamMach1's Avatar
Default RE: who sells MGW sts?
ORIGINAL: rygi23
Thanks for the input. Let me ask you this...normal daily driving do you give the engine RPM a little time to drop given the shorter time needed for shift or does it feel fine to just roll through the gears? Thanks bro.
Depends. If I'm driving to get somewhere, I'll just plow through the gears like a breeze. But most of the time, I pop the clutch in, wait maybe a second, if that, and then pop it back into gear. It's a little tough timing things right when you first get the shifter on because before it was like this...
Long push for clutch
Long throw for the shifter
But with the new shifter it will be like...
Short throw for the shifter
So you just got to get used to it and then you will find that comfortable timing.
HamMach1 is offline
Old 03-30-2008, 11:25 PM
  #22
B.O.B MACH 1
ORIGINAL: rygi23
jmac72187 informed me that stangmods.com sells them, just incase anyone asks u in the future about the MGW
I checked stangmods and they had hurst steeda and another brand i cant remebr but they didnt have the mgw. Thanks for the info though.
B.O.B MACH 1 is offline
Old 03-31-2008, 05:22 AM
  #23
jmac72187
corner carver
jmac72187's Avatar
Just drive it normally. It is shorter, but daily driving you don't have to rip each gear fast. Just shift normal speed.
jmac72187 is offline
Old 03-31-2008, 09:13 AM
  #24
USMCrebel
Mach I Section Moderator
+1, i drove a cobra with the MGW before my mach and found even though you could shift like Steve McQueen, its just as satisfying shifting normally
USMCrebel is offline
baddog671
07-26-2016 01:20 PM
b8checker
10-08-2015 12:55 PM
Matt's 95 Stang
10-05-2015 07:16 AM
mdg
10-01-2015 07:04 AM
UrS4
09-30-2015 10:13 AM
Featured Sponsors
