what is wrong with my Transmission
when i shift my car fast at a high rpm going in to 2nd gear ill get a grind but its going in to the gear i thought it might have been the hurst shifter i put in so i took it out and put the stock one in back in but its still grinding with the stock shifter some one PLEASE HELP its driving me nuts
RE: what is wrong with my Transmission
this sounds dumb but make sure your seat is up far enough and you hold the clutch in long enough. I was having the same problem at the track and i moved my seat up an inch or 2 and problem solved.
+1 on the syncros. +1 on changing your tranny fluid
Did you buy this car new or used?
If used the previous owner drove that car hard.
Perfect opportunity to upgrade your tranny to a T-56
Good luck!!!
Good luck!!!
Yorp.. I would say it's definitely a synchro, as my 3650 did the same thing when I still had it. I would look into getting a new synchro kit, before you shear the teeth off of the gears brudda. And yes, I meant to say yorp.. I'm in a screwy mood today.. lol
