Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Ipod in a 2004 Mach 1 with Mach 460
Old 07-29-2008, 02:00 AM
clarehills
clarehills's Avatar
Default Ipod in a 2004 Mach 1 with Mach 460
Hi, has anyone figured out how to hook their ipod into the mach 460 without having to use one of those crappy radio transmitter deallys?
Thanks,
Clarehills
clarehills is offline
Old 07-29-2008, 06:21 AM
Sparks232
Sparks232's Avatar
Default RE: Ipod in a 2004 Mach 1 with Mach 460
i got one from circuit city, i had to tap a 12V power source and a ground wire also, only downside is my raido is not functional anymore. i had to take out the center block plug to put the ipod one in there, and i guess it controls the raido stuff. im not too worried about it because all the music i like with no commercials are on my ipod haha, if you want i can try to get the part number and brand namefor that ipod cable when i get home. i know someone on M1R figured out this brand that hooks up to the 460 and doesnt affect the am/fm raido operation. if i remember right it was around 120 bucks though.
Sparks232 is offline
Old 07-29-2008, 08:35 AM
DesertMach
DesertMach's Avatar
Wasn't there an adaptor for that, I remember i big discussion on it at the M1R, you can add this adaptor that will give you a set of RCA inputs to the Mach 460, this works through the cd input somehow, and it does not use FM frequency modulation. I think the adaptors were about 80 bucks through Crutchfiled.
I think itwas more compatable with the 04 than the 03, but that may have been the satalite radio discussion.
DesertMach is offline
Old 07-29-2008, 11:38 AM
jmac72187
corner carver
jmac72187's Avatar
There are many different ways to do this. A lot of different kits and adapters will do it in different ways.
I personally have used the Harmon Karndon system with success. You never see the iPod and it sounds decent. It works through a radio transmitter, but the transmitter is inline. It is literally hardwired into your antenna radio. I never had issues with reception. The sound did seem a bit flat with a slight lack of bass but for $100 (then) I couldn't complain. I think the kit is probably about $40 on eBay now.
jmac72187 is offline
Old 07-30-2008, 10:41 AM
clarehills
clarehills's Avatar
Hey Guys,
thanks for the input.
Sparks232 - I deffo want to keep my radio - thanks for the pointer though
DesertMach - Yep, I think it was called the DF-Ford 20 USA DSpec or something like that - I had it hooked into my 2003 GT and loved it (before it was totaled). I was going to get the same thing again but crutchfield is telling me that it is not compatible. I thing the Mach460 I have in my 04 is different from the one in the 03 - it has a SAT button...
jmac72187 - Thanks - I will see if I can get a hold of one of those and try it out
lincolnshibuya
12-08-2015 04:37 PM
lincolnshibuya
10-06-2015 08:45 AM
jrrhd73must
10-02-2015 09:17 PM
breaking
10-02-2015 01:27 PM
Sixer4Life
09-29-2015 07:03 PM
Quick Reply: Ipod in a 2004 Mach 1 with Mach 460
