Intake Spacer Install... I ****ed up
#21
RE: Intake Spacer Install... I ****ed up
Right now the screw is pretty haggard haha. There is a hole through it because I the broken drill bit came out the bottom. It was a pretty small bit though. Either tomorow or Friday I am going to dive into it and get it done.
I will try the extractors again and if that fails I will attempt the screwdrivers and maybe a dremel.
The car runs fine, but I just can't live with it like that.
#22
ORIGINAL: jmac72187
#24
+1 Try to drill out toaccomodate biggest easy out you can use.. Left handed as mentioned would be A++++ That is a tough perdicament you have gotten yourself into lol I feel the same as you though Gotta get it right!! You're doing the right thing and I applaude you[sm=happy046.gif]
#25
You could possibly take the lower intake to a machine shop and see if they can do anything to get it out. This is a bad situation. A friend of mine managed to do the exact same thing on his 5.0 but never was able to fix it, mainly because he used counterfeit grade 8 bolts that cannot be machined out.
#26
How hard is the removal of the entire intake manifold? I would obviously prefer to avoid this but if the extractors don't work it could come down to it.
Worst situation is that I live with it like this until the winter and remove the manifold to have it removed while the car is away for winter.
#27
ORIGINAL: jmac72187
#30
